Emissions issue: Will not reset "not ready" flags
Old Nov 12, 2007 | 05:50 PM
2000GTP's Avatar
I have emissions due up and as the last time, the car is fighting me. I did do some work to it that required me to disconnect the battery a couple weeks ago so I am aware that this will reset the PCM. However, I have done a great deal of driving in it, at least 300 miles worth, which has been a mix of city and alot of expressway driving. I am still getting "not ready" statuses for the front 02 heater circuit, the EGR system, and the rear 02s. Despite the headers, the EGR system is still intact and has not been tuned out and there are 02 sims in place. When I took it in for emissions a couple years ago, I had issues with the same three things, but after a week of driving, the car finally passed. I am starting to worry as it has been over a week now and I have been doing alot more driving as compared to the last time. Do you think if I follow this procedure to the dot that it might do the trick? http://www.obdii.com/drivecycle.html Or is there something else I can maybe try or have overlooked? Also, my PCM has been tuned by Ion, but he did not tune out any sensors. Thanks for any advice offered.
Old Nov 12, 2007 | 06:29 PM
93v8clone's Avatar
What Temp Is Your Car Runnin At I Have Seen The Same Thing Happen If It Cant Reach "operating"tempor If A Full Cold Soak Hasnt Been Done So Verify Its Comin Up To Temp And If It Is Make Sure You Let It Sit Overnight And Drive It At Least 70 80 Miles At Runnin Temp Anf The Monitors Should Run We Have The Same Thing With Inspections In Our State All Monitors Have To Run And No Lights
Old Nov 12, 2007 | 07:13 PM
2001NBMZ28's Avatar
That OBDII drivecycle should work to perform all tests, don't think you have to follow it exactly - just as close as you can. Might take a few tries though since the battery was disconnected. Usually the EVAP is the hardest, but not your issue. Some states let you get away with a couple not readies depending on the year as long as the SES isn't on. So glad we don't have testing down here.
Old Nov 12, 2007 | 07:22 PM
2000GTP's Avatar
IL allows 2 not ready codes, right now I am at 3. The car does sit at idle for most of the time. I'm no expert with the OBDII programming, but I wonder if the car sitting around as much as it does has "catching up" to do in regards to the monitors.
Old Nov 12, 2007 | 09:38 PM
93v8clone's Avatar
Car Neads To Be Driven For Onitirs To Run Not Idaling And The Only Monitors You Have Left Are The Ones That Run From A Cold State To A Hot State In Morn After Car Sat All Night Drive It 60 Miles Give Or Take Without Shutting It Off And I Bet Ya They Will Go I See It All The Time At My Shop
Old Nov 13, 2007 | 10:12 AM
RE AND CHERYL's Avatar
Those O2 sims are the reason for your OS sensor not ready.
Re'
Old Nov 13, 2007 | 04:57 PM
93v8clone's Avatar
Ive Had 02 Sims On Before On Other Cars No Problems With The Monitors Not Sayin They Dont In The Few Ive Had Or Seen No Probs
Old Nov 14, 2007 | 12:13 AM
You normally won't see a problem as far as the SES light being on. Problem is the OBD II testing stations are getting smarter. Here in De a year ago you could reset the SES light and drive right to the DMV to get tested. That dosen't work now. I also know someone with O2 sims that has not been able to get the car through testing with them installed. Keeps reading system not ready.
O2 sims are crap anyway. Just have the rear O2s tunned out. If you can't because of testing then you have to have cats anyway. If you have cats then you might as well have rear O2 sensors installed. Kind of a crazy circle.
Re'
Old Nov 14, 2007 | 09:07 AM
2000GTP's Avatar
A little more info, a couple years ago, the car did pass with the exact same mods and tuning. It is being stubborn this time around though and still hasn't reset the monitors. I am going to try disconnecting the battery later to reset the PCM and start from scratch and see if that will do the trick. Otherwise, the car does have cats, I may have 02 bungs welded in and just reinstall the rear 02 sensors if it comes to that.
Old Nov 14, 2007 | 01:42 PM
resetting the PCM agina will just lengthen the time the system will require to test properly.
Re'
Old Nov 29, 2007 | 03:20 PM
FAST96Z's Avatar
i had the same problem and after 5 months sra transmission (buddy) he tunes the camaro when you go in and put a check in the exempt box that still dont work you tune the car and just leave the boxes empty instead of checking them off hope you understand if not pm me and ill explain more but i know what your going through later
eric
Old Jan 22, 2020 | 08:11 AM
dickeymoore's Avatar
Re: Emissions issue: Will not reset "not ready" flags
Is that 60 miles straight hwy or just 60 miles to get monitors to be ready after cold state?Thanks
Old Jan 22, 2020 | 09:01 AM
”93v8clone” hasn’t signed in to this sit for 9 years.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
surreybrad
Jul 29, 2015 02:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Boss002
Jul 9, 2015 03:33 PM
