Tire Pressure At The Track?
Old Jul 25, 2007 | 10:13 PM
Bill'sWS6's Avatar
I just went from running 17X9.5 ZO6 Motorsport rims to 15X10 rear and 15X4 front ProStars. I was able to shed about 100lbs in rotating mass. So, I can't wait to see what new times I get. I ran a best of 11.98 last year.
Anyway, with my old setup I ran 275/40/17's MT ET Street Radials and lowered the pressure to about 20lbs at the track. This worked pretty well for me. Now I am running 275/50/15 MT ET Street Radials. I was told I should not have to drop the pressure as much because of the taller sidewall of the new rear tires. It was suggested that I start around 28lbs and work my way down from there. I figure dropping 2lbs at a time would work best.
So, who runs a similar setup and what do you find works well for hooking tire pressure wise? The car makes about 436RWHP and 410RWTQ on a dyno jet.
Oh yea, any ideas on what I can expect for improvments in my times going from what I had to the new setup? I was hoping to see .20 better times?
Thanks in advance for your help!
Bill
Old Jul 26, 2007 | 04:22 AM
AL SS590 M6's Avatar
I'm running the same size Hoosier DR and found that 22psi works very well.
100 lbs of rotating mass will have the same effect as 300-400 lbs of static weight. When I went skinnie fronts I lost 34 lbs and a solid 1 tenth in et.
So I would say 3 tenths and 3 mph. But remember the weather is horrible for drag racing right now and the gains might be swallowed up by the heat.
Old Jul 26, 2007 | 08:48 AM
Bill'sWS6's Avatar
Thanks Al,
I also got all of that audio/video equipment out of the car and removed the rear seats. This allowed me to drop another 100lbs. So, I dropped about 100lbs off the rims and tires and another 100lbs off with removing the audio/video equipment and seats. I am looking for another 50lbs to drop in ASAP. My goal was 300lbs but will settle for 250.
I saw your post about Stanton. If I had a truck and trailer I would head up there in a heartbeat. I am just affraid of breaking down 100 miles from home. I'll probably head to Milan next Wednesday and get there when the gates open. This should give me 4-5 good passes before it gets busy.
Thanks,
Bill
Mar 13, 2016 03:39 PM
wytblur
Aug 5, 2002 02:03 PM
Brady
Jul 29, 2002 10:30 PM
MYT30TH
Jul 28, 2002 08:47 AM
Corp
Jul 22, 2002 02:17 AM
