Bolt Pattern on 4th Gens
Old Jul 9, 2007 | 06:58 AM
yacka's Avatar
Hi, I just found the post regarding the bolt pattern on the 4th gen cars and you state that the bolt pattern is 5/4 & 3/4 inches (120.65mm) I have been led to believe that it was changed to a metric size of 120.20mm (euro cars) - This is from a wheel dealer here in Australia that gets his wheels from USA , he was adamant that this was the case. I have had conflicting info from other wheel dealers here that say the 4th gen bolt patterns are the same as earlier camaros - I know the thread is metric.
I tried to fit earlier model camaro bolt pattern wheels which has the same pattern as our earlier model Holden vehicles (aussie gm's) but found that the offset was too far outwards (the wheel extended past the fender)
can you please confirm that the bolt pattern is 120.65mm and is this the same as earlier model Camaro's/chev's
regards John Yacka
Old Jul 9, 2007 | 05:52 PM
The 3rd and 4th Gen F-Bodies, and the corresponding year Corvettes have a bolt pattern that is 5 x 4-3/4". 4-3/4" (4.75") converts mathematically to 120.65mm.
4.75" x 25.4mm/in = 120.65mm
This is absolutely correct - no question.
Old Jul 9, 2007 | 06:16 PM
yacka's Avatar
RE Bolt pattern 4th gens
Thanks for that the confirmation, so is this late model pattern the same as earlier Camaro's/Chev's eg. 2nd gens? What is their dimension.
Cheers Yacka
maybe2fast
Mar 16, 2015 09:45 AM
Roadie
Feb 16, 2015 10:34 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
