SCR's relationship to DCR
Old Jun 24, 2007 | 10:04 PM
1LESSZ28's Avatar
Lets say you have two motors and both have 8.8 DCR but one has 11.6:1 SCR and the other has 10.4:1 SCR - will there be a difference in detonation resistance/vulnerability (assume quench is the same for both, cooling etc.)
Simple question: does scr have any role in determining detonation vulnerability/resistance or is this stictly related to dcr?
Also, how about increasing compression via decreasing the quench (0 deck gasket)? I had another thread where I noted that a cc464 (lt1 specific cam) has an ivc of 55 which puts the dcr at or above 9:1 (depending on specs you use on a stock motor). Leads me to believe running a 9:1 dcr with a quench around .035 better cooling and a tune should be no problem?
Old Jun 25, 2007 | 05:41 AM
rskrause's Avatar
What is STR?
Rich
Old Jun 25, 2007 | 09:26 AM
FASTFATBOY's Avatar
Rich I think he means SCR, static compression ratio.
David
Old Jun 25, 2007 | 10:51 AM
jerminator96's Avatar
David
He used STR an awful lot though, with SCR mixed in.
Old Jun 25, 2007 | 10:57 AM
1LESSZ28's Avatar
fixed and sorry about the confusion.. I had one too many and tc's on the mind lol.
Old Jun 25, 2007 | 11:01 AM
1LESSZ28's Avatar
And yes fastfatboy it is indeed static compression ratio or SCR. hope it makes sense now.
Old Jun 25, 2007 | 01:30 PM
rskrause's Avatar
Yes, there is a big difference.
Think of DCR as related to low rpm/high load detonation and SCR as playing a role at high rpm/high load conditions. When in the region of peak torque at WOT, the VE is at its' peak and cylinder pressures will be quite high. Due to increased cylinder filling and less time for the mixture to escape after BDC but prior to IVC. That's why you can't run 14:1 with a huge cam on pump gas. You would get excessive cylinder pressure and detonation at WOT, especially near peak torque rpm, even though it might run good at low rpm. This is even more the case with a boosted motor, which sees very high VE over a wide rpm range and needs a low SCR to run on pump gas regardless of DCR..
Rich
Old Jun 25, 2007 | 07:54 PM
FASTFATBOY's Avatar
Rich
Really it depends on the whole combination of parts that get you there....tight quench and VE play a HUGE part when dynamic compression limits are being pushed. 9.0 to 1 DCR is the understood limit on pumpgas, I am running 13 to 1 SCR with a DCR of 8.7 to 1....I am at the limit for my climate. But I got a BIG cam, tight quench and a BIG cooling system.....I am still in the phase of working the bugs out...but it does run warm.
David
Old Jun 25, 2007 | 07:56 PM
rskrause's Avatar
I wonder with the DCR that high if you will have trouble at high rpm/high load? I hope not.
Rich
Old Jun 25, 2007 | 08:24 PM
automotivebreath's Avatar
David,
Can you tell us more about your combination? Bore, stroke, camshaft,
heads, intake and total ignition advance?
Old Jun 25, 2007 | 08:45 PM
FASTFATBOY's Avatar
Originally Posted by automotivebreath
David,
Car has not been tuned, has a break in tune.....I will have it tuned by Ed Wright shortly...having trans issues. The car does run well though.....hard to tell anything without a tune though. I have driven it...runs GOOD!
If you really want to know the combo I will pm you.
David
utahbound
Nov 19, 2003 07:29 PM
Zero_to_69
Advanced Tech
10
Jul 11, 2003 11:14 PM
AdioSS
Advanced Tech
11
May 23, 2003 07:39 PM
Kraest
Advanced Tech
Mar 9, 2003 04:24 PM
Kraest
Mar 6, 2003 11:57 AM
