machine wok help
Old May 21, 2007 | 04:43 PM
james_8997's Avatar
machine wok help
im buildin a 388
(.060x3.750) any ways the machine shop asked me if i wanted a standard bore and hone job($150) or bore and hone with a torqe plate($250) can someone feel me in on what that means and is it worth the extra 100 bucks. im goin for 550hp on motor and a lil shot of NOS its a street/strip car (1988 camaro)
Old May 21, 2007 | 07:35 PM
LiENUS's Avatar
Definately get the torque plate. When you torque down the heads and all associated equipment the bores shift a little, the torque plate simulates this so the bore is truer to the situations that the cylinders will see in real life rather than a situation with no stresses on the block as in a normal bore.
Old May 21, 2007 | 08:40 PM
MachinistOne's Avatar
Get the TQ Plate hone, you can tell a block that has not been honed that way after running it by the shadows that show up on the cylinder walls, at even points matching the locations of the head bolt holes.
Old May 21, 2007 | 08:41 PM
rskrause's Avatar
If they had to ask, consider another machine shop.
Rich
Devinfoote87
Feb 12, 2016 03:21 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Aug 14, 2015 03:02 PM
Jul 17, 2015 02:47 PM
