Found out why my window won't line up...how am I going to fix this one.
Old May 10, 2007 | 03:35 PM
bdc95ta's Avatar
Here are the pics, I guess one of the rivits initially was loose and over time caused this. Am I going to have to buy a new door?
-b
Sorry the picture quality sucks.
Old May 10, 2007 | 04:04 PM
camarozz95's Avatar
wow the same thing happend to my 95 when I had never thought I would see another car that had this. My dad and I fixed I wish I had pics to show you but I don't have the car anymore. we had to make a new support for that rivet we bought a metal bar(looks like ruler shaped) from home depot and cut it into two small pieces, and made almost a backwards "L" shaped thing to bring the rivet back to its original position. ha its really hard to explain can't exactly remember how we did it, but it can be fixed.
just for clarification your window won't go all the way up right? it just stops near the top so it looks like its all the way closed, but its just not quite there?
Old May 10, 2007 | 04:09 PM
bdc95ta's Avatar
"just for clarification your window won't go all the way up right? it just stops near the top so it looks like its all the way closed, but its just not quite there?"
Exactly yes just in the front there's a small gap by the side mirror. I was thinking about something like that did you just drill holes in the fiber to hold it in place. And why an L shape is it for clearance back there it's difficult to see.
-b
Old May 10, 2007 | 04:12 PM
bdc95ta's Avatar
One of the rivits and that hook from the regulator are both in bad shape. Probably need two brackets.. was your's as bad as mine?
-b
Old May 10, 2007 | 04:13 PM
camarozz95's Avatar
right we just drilled into the fiber to hold it, and I'm pretty sure we put the supports on the front of the door, and the door panel still fit over it with no problems.
did you just buy the car? because thats what happened to me guy said window motor was dead then when we went to go change we found that.
Old May 10, 2007 | 04:14 PM
camarozz95's Avatar
-b
in your first picture I think that was the one that was bad on mine the others were still ok. oh and im pretty sure we drilled out the rivet and used a nut and bolt to go through our metal supports that we made
Old May 10, 2007 | 04:17 PM
bdc95ta's Avatar
No I've had the car for 6 years it's just been down awhile. I replaced the motor w/ my friend (roughly 3 yrs ago) and on the last rivit he broke the gun. I don't know how but he did. Anyways I think it didn't quite go in right which caused this over time. Thanks for your help off to home depo.
-b
Old May 10, 2007 | 06:32 PM
shoebox's Avatar
Either use a fiberglass patch or attach some metal as already suggested. Gee, those are some of the most out of focus pictures I have seen lately.
Old May 10, 2007 | 11:07 PM
bdc95ta's Avatar
Thanks shoebox! How's this one?
I know it's getto but the window lines up great in the front now.
Old May 11, 2007 | 07:12 AM
shoebox's Avatar
Much better.
Old May 11, 2007 | 08:46 AM
camarozz95's Avatar
nice very close to what I had but only one of my rivets was tearing through the fiberglass. looks good
Dec 1, 2016 05:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jazsun
Dec 29, 2014 12:14 PM
DougJ
Aug 29, 2002 12:51 AM
HuJass
18
Jun 24, 2002 09:19 PM
