New rear gear...computer ok?
Old Apr 19, 2007 | 04:02 PM
eagleknight97's Avatar
In a few weeks ill be putting Motive 3.42 gears in the rear, replacing the 3.23's that are in there now. The rear was howling pretty good so I decided to give the rear an overhaul and there was no difference in price between the 3.23's and 3.42's so I opted for the slightly better performance, although im not expecting much of a difference. Anyways, any need for a computer tune to get the car to think everything is normal?
Old Apr 19, 2007 | 04:21 PM
Moshbmx1's Avatar
Your MPH will be off but the computer wont function any differently
Old Apr 19, 2007 | 04:23 PM
2001NBMZ28's Avatar
You mean other than the speedo being off? Probably not, those ratios are pretty close.
Old Apr 19, 2007 | 04:30 PM
Alright, thats what I figured, just something small. The computer will be geting re-tuned later in the summer, itll just be a few weeks itll be off. I was mainly worried about the trans freaking out or something.
Old Apr 19, 2007 | 06:06 PM
At a true 60MPH, your speedo will indicate 63.5MPH. For every 1000 actual miles that you drive, your odometer will show 1,059 miles driven.
Old Apr 19, 2007 | 10:45 PM
A computer tune will fix that though, correct?
Old Apr 20, 2007 | 08:10 AM
Capn Pete's Avatar
Yeah, re-program for the correct gear ratio and everything will be 100% .
Since you're not switching drastically between ratios, I think you'll be ok, but I've heard that when going extreme (say from 2.73's up to 3.73's/4.10's) that the computer (which controls both upshifts and downshifts) should be re-programmed before ragging on the car, because the tranny may have odd shifts/shift-points, because the speed ramps up much quicker, and the computer may allow shifts to occur when/where they shouldn't . You can still DRIVE the car (I have myself) but from what I've heard, it's not recommended to drive it too aggressively, which I never have until I've re-programmed for the gears.
Like I said though, since you're only going from 3.23 --> 3.42, that's probably not a big deal ... try it out and see .
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
