autometer trans temp install
Old Apr 17, 2007 | 10:50 PM
slicknick54's Avatar
How do i install a electric trans temp gauge . do i drill a hole in the pan? Thanks again
Old Apr 17, 2007 | 10:55 PM
2000GTP's Avatar
This is a good place to put the sending unit: http://shbox.com/1/a4_plug.jpg
Old Apr 17, 2007 | 10:59 PM
is that there on the 97? thanks for all your help lately
2000GTP's Avatar
It shouldn't be any different.
Old Apr 17, 2007 | 11:01 PM
Moshbmx1's Avatar
Should be the same, thats the same spot im mounting mine
Old Apr 17, 2007 | 11:02 PM
how did youy guys tap into your illuminating wire>?
Old Apr 17, 2007 | 11:26 PM
When i install my two gauges what fuse do you guys wire them to and where do you wire them so they light up. where can i also find paint to paint my pod the same as my interrior. (sorry for the questions i just want to know the right way the first time)
Old Apr 17, 2007 | 11:46 PM
2000GTP's Avatar
You need a 12+ volt switched ignition source which you can pull out of the fuse panel block on the side of the dash to actually power the gauges. As for the ground, you should be able to find a bolt or screw that is screwed into the chassis sheetmetal. Once you remove the panel that is below the steering wheel, you should find a couple. As for the gauge lighting, there are a few sources you can pull from the dimmer circuit fuse in the fuse block, the headlight switch, or the instrucment panel dimmer switch.
Old Apr 18, 2007 | 01:09 AM
ttop1986's Avatar
I remember reading that the test port on the tranny, will give you the reading of the case temperature rather than the fluid itself, because the fluid doesn't reach all the way up there. Not sure that makes much of a difference, but I am going to put mine here:
a writeup here http://ken.lowrance.com/projects/TransCooler/
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
