4l60e stuck in gear/no movement
Old Apr 17, 2007 | 01:59 PM
gex598's Avatar
What would cause a 4l60e to be stuck in a foward gear? I purchased the car knowing the tranny was dead but this is kinda weird. I've disconnected the shift linkage and manually put it into netural and the car is still stuck in gear, I cant even push it in reverse, itll only roll foward. Regardless of which gear it is in if I start it and give it a tad of gas it will crawl foward, even in park! I've got a fresh tranny and converter sitting here but was curious about what could of caused it. BTW anyone need 3 dead 4l60's?
Old Apr 17, 2007 | 03:28 PM
jay_lt4's Avatar
well if it is not a linkage problem, i would say the clutches are welded together from heat
Old Apr 17, 2007 | 04:44 PM
12SCNDZ's Avatar
Forward clutches "welded" to the forward steels.
Frank
CPT
Old Apr 17, 2007 | 07:00 PM
apss's Avatar
i had the forward clutches weld together.had to clean the valve body 3 times."say no" to N to D drops
Old Apr 18, 2007 | 07:01 AM
gex598's Avatar
Had a hell of a time getting the driveshaft out last night so I could bring it into the shop. The driveshaft would slide foward into the tranny at all, even with the aid of a hammer!!! I managed to use a prybar to pop it out looks like I need to replace the ujoints now too. Welded clutches ouch, I guess that means the prior owner beat on the car huh lol.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 11:56 PM
CARiD
Sep 30, 2015 05:44 AM
