How is this cam
Old Apr 6, 2007 | 02:32 PM
JohnnyPappis's Avatar
How is this cam
This cam is for a 396 H/C/I LT1 runnig a T88 I got this cam with my Trickflows from loyd elliot and while i trus there judgement this cam dosent look like the turbo cam profiles ive seen heres the cam card
Intake Exhaust
Valve Adjsutment Hyd Hyd
Gross valve lift .568 .571
Duration @
.020 Tappet Lift 275 272
Valve Timing Open Close
@. .050 Int: 0 BTDC 44 ABDC
Exh: 57 BBDC 5 ATDC
These Specs are for the cam installed
@ 112.0 Intake Center Line
Intake Exhaust
Duration @ .050 224 242
Lobe Lift .3790 .3810
Lobe Seperation 114.0
Can anyone help me with my question on why this looks so diffrent from other profiles ive seen mainly i just want to make sure i can reach my power target power which is 700ish thought a Th400 and Dana 60 rear ?
Old Apr 6, 2007 | 09:53 PM
engineermike's Avatar
It's not all that different from my cam. It's 224/236-114 and I'm running a T76, 388, AFR 210's, and made 695 rwhp through a TH350 and 9" at only 17 psi. You got more cid, more turbo, and more exhaust duration, so I think 700 won't be a problem.
Old Apr 7, 2007 | 02:23 PM
ALright that answered my question....now i need to finish her up and get her on the dyno then the track to see what she will do Hopefully i will suprise myself with the dyno numbers and as for the track.....well im not one for making predictions so im taking a wait and see approch to that Hopefully ill be pleasentlly suprised
Old Apr 9, 2007 | 09:11 AM
RealQuick's Avatar
Ron - you'll make the numbers no problem. The whole turbo cam theory is up in the air, seems like you can make power with any cam and a turbo lol
Old Apr 9, 2007 | 12:05 PM
roguedriver's Avatar
Post your dyno numbers and a vid if possible. We all love crazy turbo/blower dyno videos here...
Ken R.
Old Apr 9, 2007 | 12:58 PM
Ken R.
Oh you'll all be getting dyno numbers Track numbers and vids!
Old Apr 9, 2007 | 01:00 PM
So ive knoticed i just wanna make the most i can
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
