How to check fuel pump check valve. ? FP issue.
Old Mar 31, 2007 | 04:26 PM
DR.ZED's Avatar
Racetronix Walboro pump kit. Worked fine, but car sat for a year and a half and this started. FP at prime (or with the pump running with the connector by the PCM) is 55 psi. Stop the pump and the pressure bleeds to 0 within 10 seconds.
Changed the FPR to an Accel unit. Pulled the rail and no leaks. Bypassed the return line to check for kinks. Nothing works.
What is this bypass in the fuel pump thing? Can somebody direct me on how to check this? That sounds like the ONLY thing left.
Thoughts?
(BTW, check out this post, sounds like the same thing: http://web.camaross.com/forums/showp...33&postcount=6)
Old Mar 31, 2007 | 09:23 PM
RE AND CHERYL's Avatar
The check valve only keep fuel from draining back into the tank. It does nothing to keep the preasure from going away. Is the car actually having problems starting?
Re'
Old Apr 1, 2007 | 09:23 AM
DR.ZED's Avatar
Yes.
Racetronix pump. Primes to 55 PSI. I can run the pump at 55 PSI with the connector by the PCM. Take away power FP drops to 0 within seconds.
Took the rail off. Injectors do not leak.
Took off return line for suspected kinks on the way back to the tank. Same scenario.
Replaced FPR with Accel ADFPR same situation.
Gas cap holding pressure. (but it is old).
Old Apr 1, 2007 | 10:40 AM
Re'
Sure is does. The check valve needs to stay closed to hold the pressure in the lines when the pump shuts down. The FPR hold the return line closed, hopefully there are no leaking injectors, and the check vlave is closing off the supply line.
Old Apr 1, 2007 | 11:15 AM
Wierd. MY car will loose fuel pressure within 20-30 sec after turning the key off and I have had no problems starting the car ever.
Old Apr 1, 2007 | 11:27 AM
DugRat's Avatar
I had a small leak in the teflon line that runs from the Ractronix pump to the metal line inside the tank. I replaced it with a piece of fuel injection hose from NAPA and no more problems.
Old Apr 1, 2007 | 02:31 PM
DR.ZED's Avatar
Time to cut the hatch floor to get at the pump...
hmmmm....
Old Apr 2, 2007 | 12:17 AM
69gto96z's Avatar
Which hose are you talking about?
RiverMutant96
Jan 30, 2015 09:21 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
