Should I go ahead and get bigger injectors?
Old Mar 20, 2007 | 09:06 PM
kgkern01's Avatar
I have to replace a bad head gasket and am installing some ported heads in their place while I'm at it. My engine has about 150k on it so I am refreshing the whole top end. Should I just get the stock injectors checked out and get bigger ones later, or should I go ahead and get bigger ones and just have the PCM retuned for them? I will be full bolt on including 1.7RR with the ported heads. Not doing cam until I can afford a rebuild.
Old Mar 21, 2007 | 01:01 PM
2000GTP's Avatar
If you don't need bigger injectors, then I wouldn't get them. Otherwise, if you do upgrade to a larger size, you are going to have to spend additional on a tune to avoid running rich. Also, swapping out injectors is a pretty easy task anyhow as the fuel rail pretty easily pops up so it would just make sense to wait.
Old Mar 24, 2007 | 10:08 AM
RE AND CHERYL's Avatar
You don't need them. It wouldn't do anything but put a big hole in your wallet.
Aug 22, 2015 01:09 AM
nd4spd200
Aug 21, 2015 09:30 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Anon
Jul 23, 2015 12:18 PM
13qtr
Jul 19, 2015 05:30 PM
