car missing please help cant find the problem
Old Mar 18, 2007 | 08:55 AM
Garcia95's Avatar
hello everybody about three weeks ago my car started nissing and i school i connecteded to the tech 2 and scanned the computer. it camo out that the cam senser had no signal so i changed the sensor, and the problem continued. then i discovered a vacume leak from a pcv valve i fixed the problem and the ratteling continued. i then decided to change the spark pluggs. and the problem continued. i cant find the problem so please if anyone has been through something similar and came out of it with a working car tell me how you did it. by the way when im i a dead stop and accelerate fast the car starts nissing.
Old Mar 18, 2007 | 10:33 AM
smithtim's Avatar
misfire on the 3.8 is often caused by the plug wires, but usually get a 0300 code and could be other things... perhaps hook it back up to the scanner since you changed that sesnor and see if it is regestering a ranom miss
Old Mar 18, 2007 | 12:26 PM
2000GTP's Avatar
I would get it scanned and quit guessing on parts, otherwise you'll spend a ton of money. See if there is a misfire to a specific cylinder. If so, then start the troubleshooting with the coil pack, plug, wire, and fuel injector.
Red Hawk 94
Mar 18, 2019 04:03 PM
cmdeshon
Dec 12, 2014 10:51 PM
bernie1951
Dec 10, 2014 10:03 AM
Sarahrope64
Nov 27, 2014 11:17 AM
USAirman93
Nov 24, 2014 03:37 PM
