zex questions
Old Mar 15, 2007 | 07:23 PM
fbodyboy's Avatar
zex questions
i'm getting a used zex kit for 200 from a good friend, i was wondering how you guys installed the fuel line. i was thinking about installing it in place of the schrader vavle, but what size of fitting do i need? i was planning on running a 75 shot on a realitivly stock motor with the usually saftey accessories and colder plugs. you gus got any tips and suggestions?
Old Mar 15, 2007 | 09:53 PM
Ray@NitroDaves's Avatar
you will pull the fuel from the test port on the fuel rail....you will remove the schrader valve from inside the test port and the 4an fuel line will screw directly to the port on the rail
Old Mar 15, 2007 | 10:48 PM
fbodyboy's Avatar
thanks for the help, i should have it on there soon.
Old Mar 16, 2007 | 01:31 PM
2000GTP's Avatar
As Dave mentioned, take the little valve out of the schrader fitting. I found one of those tire valve core removal tools from Wal-Mart works best. Just be careful with the valve once you get it out, if you drop it, you probably lost it for good.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Brendans Z
Sep 11, 2002 05:29 PM
