Window switch?
Old Feb 23, 2007 | 08:57 AM
mcshocks's Avatar
Window switch?
Looking to get a window switch with gear lockout features, from what I can see the ZEX 82085 switch looks nice but any other opinions on reliability and/or other products that may be better would be great.
On another side note has anyone had good luck with the fire and ice (bottle heater/cooler) unit by NX.
Old Feb 23, 2007 | 09:02 AM
Ray@NitroDaves's Avatar
The Zex unit is a nice piece but does not come with TPS activation.
Our switch has all the features of the Zex plus TPS activation , and it is cheaper.
THe 860 Performance heater is our best selling unit.
Old Feb 23, 2007 | 09:13 AM
mcshocks's Avatar
- I take it then I wouldn't need a manual TPS switch? Does it use a electronic signal for TPS activation?
-Do you have more info on the 860, as in does it only heat, and what does it do to control the variances in temperature, does it have adjustable bottle pressure settings, etc. (your website doesn't go into much detail on the piece).
Old Feb 23, 2007 | 09:44 AM
The window switch has an integrated TPS activation switch, it will tap into the wiring for the TPS sensor and will read the voltage to know when you are WOT.
The 860 heater uses an aluminum plate to heat the bottle, it has excellent heat transfer ability which helps heat the bottle with less amp draw on the electrical system. It does come with a user adjustible pressure switch. Also by integrating the heater and bracket into one piece it makes it very easy to get the bottle in and out of the car.
The downside is it does not have a provision to cool the bottle...
I am using the 860 in my 94 and really like how it does not clutter up the bottle as I plan on having my bottle custom painted. and would prefer not to cover it up.
Old Feb 26, 2007 | 11:42 PM
Nitro Dave's Avatar
Here are links to both units so you can check them out.
Digital window switch
http://www.nitrousoutlet.com/catalog...product_id=964
860 Heater
http://www.nitrousoutlet.com/catalog...product_id=693
Dave
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
