Nitrous and Mallory 685 wiring diagram
Old Feb 19, 2007 | 11:15 PM
seawolf06's Avatar
I don't think this was posted before, but it's a good diagram.
Old Feb 20, 2007 | 06:12 AM
01Z's Avatar
01Z
Yes, this is the best illustration I have seen. Thanks!
Old Feb 20, 2007 | 06:49 AM
2000GTP's Avatar
Agreed, that is a good illustration. It will definitely be of help to others down the road.
Old Feb 20, 2007 | 09:16 AM
Ray@NitroDaves's Avatar
Hope you don't mind that I saved the pic....
Old Feb 20, 2007 | 09:49 AM
69gto96z's Avatar
I wish I would of had that when I hooked my n20 up. It would have saved a lot of headache.
Old Feb 20, 2007 | 03:03 PM
seawolf06's Avatar
I don't mind, Dave. Just send me some bottle brackets or something.
This is courtesy of another member here, but I deleted the PM and can't remember the name. If anyone has a pic of how they mounted the WOT switch on the LT1, that would help me. I think I just have a microswitch.
Old Feb 20, 2007 | 03:25 PM
its an old pic...but you get the idea.
please excuse the dirty intake
Old Feb 20, 2007 | 03:27 PM
seawolf06's Avatar
EDIT: Can you explain how the microswitch works? Such as, when it's pressed in, it does this and when it's open, it does this. Thanks.
Old Feb 20, 2007 | 03:56 PM
2000GTP's Avatar
Basically, the microswitch is routed in series with the nitrous circuit and is normally in the open position causing a break in the circuit. When the switch is pressed, the contacts in the switch close, creating a closed circuit that allows current to flow and thus causing the nitrous system to activate.
Old Feb 20, 2007 | 07:43 PM
69z-28's Avatar
i mounted mine by the pedal. its very ****!!!
Old Feb 20, 2007 | 07:44 PM
2000GTP's Avatar
Do you have a pic of this? I am considering relocating mine there and wondering how people are doing it.
Old Feb 20, 2007 | 09:08 PM
Old Feb 20, 2007 | 09:14 PM
69z-28's Avatar
yep mines similar to rays. i used the a lockwasher and a few washers to space it out where i wanted it. also bent the little switch lever to get it right where i wanted it. il snap a pic next time i have a chance.
Old Feb 20, 2007 | 09:37 PM
2000GTP's Avatar
I got an idea now, thanks fellas.
Old Feb 20, 2007 | 11:17 PM
seawolf06's Avatar
So how could I use one to only work when it was "open", as in making a first gear lockout with it? Is there someway to wire the activation relay up to where when the microswitch is pressed, then it stops the system from arming?
