Dynoed my LT1.
Old Feb 16, 2007 | 06:44 PM
locrain's Avatar
Dynoed my LT1.
took my 1994 M6 to a dynojet dyno tonight. ran a peak of 234 hp at 5k, and 293.82 tq at 3.5k. it had two misses, one at 5.3, and again at 5.7. i can't get it to miss on the street, i think it is the longer time at high rpms required on the dyno (1st gear on the street goes by a lot faster than 3rd on the dyno). fuel pump or filter? the car is stock except for a cutout. i thought the tq was good, but i was expecting more hp out of an M6 with a cutout? i wasn't running quite right to, so that may be it.
edit:
Old Feb 17, 2007 | 12:11 AM
TraceZ's Avatar
That is pretty low.
My 94 M6 did 270 WRHP and 310 RWTQ with just the ramair and a borla catback. Now that i've got headers installed I'd guess it to be around 290. Is it time for a tuneup?
Old Feb 17, 2007 | 07:46 AM
locrain's Avatar
Originally Posted by TraceZ
That is pretty low.
well, what else can i do? i have already changed the opti (not that that means anything), and new ac delco plugs and wires.
Old Feb 17, 2007 | 08:28 AM
TraceZ's Avatar
Is it running right? What is the A/F ratio?
I ran mine with the cutout closed and open, it didn't make a difference with the Borla.
Do you own a laptop? Do you have a OBD1 -> USB cable? Scanning software is free, it might help you to post a data log from a dyno pull for other members to analyze.
I captured my dyno runs on my laptop, but I never bothered looking to hard at them because the graph showed what I expected.
Old Feb 17, 2007 | 08:37 AM
locrain's Avatar
well, it runs great, except that miss on the dyno that i can't duplicate on the street. i think i will be able to when i get on the interstate. don't know the a/f. have a laptop, guess i'll get a cable.
Old Feb 17, 2007 | 08:40 AM
TraceZ's Avatar
I've done more thinking about this, and your results may not be that bad.
The LT1 was rated at 275 hp stock in 94. Subtract 15% drivetrain loss for the M6 and you get 233.75. Your 234 is dead on.
I guess i didnt think my catback and ram air would be worth that much increase. I also forgot to mention I have my PCM tuned.
Old Feb 17, 2007 | 11:30 AM
matLT1's Avatar
It still seems strange that you have those dips in the dyno curve. How long has it been since you did a tune-up on the car?
Have you also considered checking your fuel pressure at WOT to make sure you aren't starved of fuel?
Old Feb 17, 2007 | 12:18 PM
2000GTP's Avatar
I agree with the above post, put on a fuel pressure gauge and observe the pressure under load. If it dips and doesn't hold steady, then that may be a sign of needing a new pump.
Old Feb 17, 2007 | 06:34 PM
locrain's Avatar
yeah, they were misses. like cutting out. it feels alot like the speed limiter. so, fual sounds likely.
truecontr3
Oct 11, 2015 09:30 AM
fift5
11
Oct 1, 2015 10:31 AM
Beave2780
Sep 23, 2015 12:37 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
