Stop Leak Additives
Old Feb 5, 2007 | 02:05 PM
Texas_96_Z's Avatar
Stop Leak Additives
Looks like my 4L60E is leaking around the pan. 101k on the clock. The fluid was changed onced at about 60k. If I replace the fluid and gasket it might croak. I do not want to rebuid it at this point. So how are the stop leak additives for these transmissions.
Old Feb 5, 2007 | 02:41 PM
GreenDemon's Avatar
Stop Leaks = Junk. I wouldn't trust anything that says it will stop leaks but not gunk up your valvebody. Just check the fluid before you do it, as long as it's not burnt you should be ok. If not, it's just a matter of time anyway and I would start saving for a rebuild and forget about the leak.
Old Feb 5, 2007 | 04:22 PM
exgmguy's Avatar
Just change the fluid, filter, and gasket. You will be fine. Or, you could try to slightly snug up the pan bolts.
Old Feb 5, 2007 | 04:23 PM
respectirocz's Avatar
any stop leak additive for any system works one of two ways
it will swell/lubricate seals to help them seal better, and it will clog up any leaks to stop them from leaking
the problem is they also clog up other stuff that we dont want clogged
you are probably better off changing the fluid
Old Feb 5, 2007 | 04:25 PM
12SCNDZ's Avatar
What "stop leak" usuallyt do is swell up rubber. All your internal lip seals are also rubber. "Stop leak" additives usually turn those seals into mush.
My advice is, if it's leaking, have it fixed right.
Frank
CPT
Old Feb 5, 2007 | 07:42 PM
Texas_96_Z's Avatar
OK
I guess I'll have to roll the dice and hope it doesnt crap out when I change the fluids etc.
BLK1997Z28
May 2, 2015 01:26 PM
May 1, 2015 01:14 PM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
