View Poll Results: Poly tranny mount: with or without the plate
With the plate because it was design like that.
23.08%
Without the plate,too much vibration,dont care about it.
10
76.92%
Voters: 13. You may not vote on this poll
Poly tranny mount with or without the plate ???
Old Feb 3, 2007 | 09:24 PM
always faster's Avatar
I ve search a lot and came with a lot of different answer.Since they dont make poly tranny mount for the 4th gen ,everyone is using the 3rd gen one:
ens-1108-r
This mount come with a upper plate that you place between the tranny and the mount itself.
A lot of member wrote that with the plate installed the vibration was really bad and when they took it off and re-install the poly mount alone, the vibration disapear.
A couple of member also wrote that since it was design like that,that you need to install the plate absolutely...
So whats the verdict on this:
Wih or without the plate???
Old Feb 3, 2007 | 09:31 PM
12SCNDZ's Avatar
There's not really much debate about this. You CANNOT use the plate on a 4th gen, or it'll vibrate the fillings out of your teeth. We get posts and calls constantly about vibrations after installing the ES mount. The cure is always to remove the plate. Yes, it'll still vibrate more than rubber, but atleast you won't break one every 5000 miles.
Frank
CPT
Old Feb 3, 2007 | 09:51 PM
Frank
CPT
Yeah i ve heard this a lot but i still think that the debate is not closed.
Look at this post: http://web.camaross.com/forums/showthread.php?t=460296
A lot of people use the plate and think that the plate has is own utility,wich one i dont know but its not there for nothing.
From Injuneer:
"I used the ES poly for 4 years with my T56.... first with the stock torque arm, and later with a Spohn TA, and never had a problem with any sort of vibrations, or with the pinion angle. It was installed exactly as the ES instructions showed, including the pre-load plate and all the bumps. Now 9 years after I bought it, its holding up the tail end of my TH400/Gear Vendor combo, and still doing its job"
Old Feb 5, 2007 | 12:57 PM
19camaro71's Avatar
i agree with what injuneer said.. This was one of the best things i've done for my car. No vibrations, no more missed gears due to high revs and the trans bein shifted. The whole car feels so much more solid with it. I have no complaints.
Old Feb 6, 2007 | 02:38 PM
Capn Pete's Avatar
I've got an ES poly mount, and regardless of with or without the plate, it causes unbearable vibrations in my car . BUT, I have the factory steel driveshaft (which I plan on taking in to have balanced this winter) and they're notorious for causing more noticable vibrations than if you have an aluminum DS.
Old Feb 6, 2007 | 03:36 PM
19camaro71's Avatar
I have the stock drive shaft as well... i've had my car up to 120mph with it and it still doesnt have any vibrations that arent expected out of a car doing 120mph.
Old Feb 6, 2007 | 04:59 PM
Capn Pete's Avatar
The vibrations I'm talking about occur at MUCH slower speeds than ~120 mph!! (I've had my car up there a few times too, and I don't find it all that bad).
It just seemed that with the poly mount, there were a couple "critical speeds" that the vibrations would just start to shake the whole car violently almost . While it is 100% worse with the poly mount, and 100% better with the stock mount, I'm NOT 100% sure it is in fact the driveshaft though? (it almost seems like it may be exhaust related, if that's even possible?? )
Old Feb 6, 2007 | 05:10 PM
CamaroSS30thAnn's Avatar
take that hunk of metal and throw it in teh garbage
ive had the plate in and teh vibrations upon accelleration were pretty bad. Took the plate out and they were gone
Old Feb 6, 2007 | 09:26 PM
19camaro71's Avatar
can someone please describe these vibrations? i have none whatsoever.. acceleration, slow speed, high speed... parked... slowing.. nothing. Am I just lucky with my peticular mount?
Old Feb 6, 2007 | 09:46 PM
blackrat's Avatar
Just put in mine yesterday, the ES one. I ran the plate like recommended.
I notice more vibration. Looking up on LS1tech, people there think it's that the pinion angle is changed. From my experimenting, it seems to be emanating because the exhaust is hung off of the mount.
I get the same vibration revving it slowly in nuetral that I do driving the thing. Clutching it in at 100 mph immediately stops the vibration.
Is there anyway to insulate the exhaust hanger more?
Old Feb 9, 2007 | 09:29 PM
the ES poly mount is higher than the stock one and doesnt compress like the rubber mount. So when u pu tthe weight of the tranny on it, it will sit higher than stock and adding the plate will make it worse. This is what throws ur pinion angle off and causes the vibrations.
Also im not sure of LS1 exhaust but the exhaust hangar is hung from that mount?
Old Feb 15, 2007 | 05:59 PM
lefty's Avatar
kinda feels like you need an alignment bad,your rotors are warped real bad, your tires are unbalanced all at the same time.I put one in a while ago with the plate and thought I screwed up my car because the vibrations. Im gonna have to try one without the plate .
Jason Short
Jan 19, 2015 06:34 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
