mac header install complete, sterring linkage rubbing flange ?
Old Jan 29, 2007 | 05:15 PM
CHELOZ28's Avatar
mac headers install complete, but know my steering linkage is rubbing my number two header flange, any ideas on how solve this?? will this be a major problem if keep on driving like this, only rubs when I turn
thanks
Old Jan 30, 2007 | 11:56 AM
Kredz28's Avatar
You have the mac mids right? That driver side header should be a 2 piece header to avoid having to remove the steering linkage. I would look into adjusting that 2 piece section.
Old Feb 1, 2007 | 02:51 PM
CHELOZ28's Avatar
Cool I will give it a try this weekend.Will it be a problem if I drive the car this way? Also I am running mac mid's true duals, no cats, bullet mufflers, dumps before the axle, is there any other muffler that will quite the exhaust sound?
Old Feb 1, 2007 | 04:19 PM
Kredz28's Avatar
Well. If if you steering linkage is rubbing your headers, id be inclined to fix it before driving it. As far as your duals go, you could get them extended over the rear axle and point it out the back of the car...that would locate the noise elsewhere.
Old Feb 1, 2007 | 09:08 PM
12SCNDZ's Avatar
Check your motor mounts to make sure they're not worn.
Frank
CPT
CobraEatr
Jul 24, 2004 11:37 AM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
