door lock mechanism problem
Old Jan 1, 2007 | 04:24 AM
93formulafirebird's Avatar
would anybody know if you can get the drivers door inner panel off with the door closed, need to get to my lock mechanism it's broken, tired of crawling out of the passenger side.
Old Jan 1, 2007 | 07:50 AM
Dave89IROC's Avatar
might be able to at least flex the panel away from the door if you pull the seat
Old Jan 1, 2007 | 04:00 PM
service bulletin
Found a service bulletin on line for 93 f-bodys.
about broken door latches.
Shows inner panel can be removed and pulled far enough towards seat to allow access, using a mirror and flashlight it shows a small opening on latch mechanism. using a icepick or scratchawl the latch can be released.
I think I will obtain my new latch before I attempt procedure
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
JoFerZ
Aug 31, 2003 12:49 AM
