700r4 no forward gears just reverse
Old Dec 24, 2006 | 11:09 PM
btcamaro's Avatar
I rebuilt my trans in my truck and everything seemed fine for the first 30-40 miles and then I lost all forward gears. It is like it is in nuetral except when it is in reverse. What do you guys think I did wrong or what should I look for.
Old Dec 25, 2006 | 09:46 AM
12SCNDZ's Avatar
It won't move forward in any manual ranges, either?
Frank
CPT
Old Dec 26, 2006 | 01:22 PM
btcamaro's Avatar
nope. It is like it is in nuetral all the time except in reverse
Old Dec 26, 2006 | 08:52 PM
Performabuilt's Avatar
Supporting Vendor
With no forward gears in any position you aparently have a major failure in the input drum and would have to have damage to both the forward and overun clutches ,You will need to remove the trans and tear it back down to find out why if you need any thing just yell ,
Old Dec 26, 2006 | 10:01 PM
12SCNDZ's Avatar
The splines in the front planetary are stripped or the splined section has broken off the front planet completely, could be one cause.
bad stator bushings that have caused a problem in the sealing rings on the input shat, could be another.
Neither the forward or over-run clutches are holding, or not tranferring power.
Frank
CPT
Old Dec 26, 2006 | 11:16 PM
Supporting Vendor
cool pretty close to what I said but with a bit more detail lol
Old Dec 28, 2006 | 08:49 AM
btcamaro's Avatar
I found what went wrong. I rolled the lip seal on the 3-4 piston by accident causing the seal to tear and get no pressure. The seal that tore ended up getting jammed into the 3-4 clutch pack and burned them up. Thanks for the replies. It sucks that I had to start over but I guess you live and learn.
Old Dec 28, 2006 | 09:51 AM
Supporting Vendor
well good luck this time if you need any information please dont hesiate to give us a call or yahoo message us we are performabuilt on yahoo messenger
Old Dec 28, 2006 | 11:36 AM
12SCNDZ's Avatar
A cut 3-4 piston lip seal won't cause a no forward condition. Are you sure it wasn't the forward or over-run piston?
Frank
CPT
Old Dec 28, 2006 | 08:13 PM
btcamaro's Avatar
It was the overrun piston I wasn't thinking strait I was up late pulling the trans out and apart
PCLZ28
Dec 24, 2015 05:19 PM
ChrisFrez
Jan 4, 2015 08:43 AM
CaRParts102
Dec 6, 2014 08:45 AM
Victory Racing
Sep 1, 2002 05:34 PM
