ghost codes
Old Dec 14, 2006 | 09:14 PM
northdakota93z28's Avatar
ghost codes
i have all kinds of codes at most times the last time i pulled them i had 12 codes, i am told they call them ghost codes i am replacing my pcm and i hope that fixes it i am wondering if anyone has heard of this if so any help is great thanks
Old Dec 14, 2006 | 10:33 PM
Multiple codes can often be caused by faulty engine and PCM grounds.
Old Dec 17, 2006 | 07:45 PM
byrons1502's Avatar
check the powers and grounds to the computer. just because they are tight does not make them good. common for multiple codes. cheapest fix also
Old May 5, 2007 | 02:56 PM
i cleaned all the ground and the codes are still there i will try a ecu and see what happens my bud is a parts man so i can get 25 percent off still 225 is alot if it doesnt fix it.
Old May 5, 2007 | 03:56 PM
shoebox's Avatar
Did you clear the codes? Most will not clear by themselves. What are you using to read them?
Old May 5, 2007 | 06:04 PM
i jumped the connector it took a bit before the codes came back because my fan stayed off for like 3 min but after that they came on again and whenever i start if they come right on. my understanding is they come on when there is hard codes.
Old May 20, 2007 | 09:42 PM
i am wondering if these ghost codes are making it so i cant shift into over drive at w o t ?
Old Jun 26, 2007 | 08:58 PM
i am buying a ecu from chevy for 250 so i hope it fixes the ghost codes i will tell you what happens when my new ecu comes.
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
ChrisFrez
Nov 23, 2014 10:33 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
