Tuning out trouble codes.
Old Dec 11, 2006 | 05:00 PM
O J's Avatar
O J
Lightbulb Tuning out trouble codes.
I can finally read my stock ECU with the piggybacked FAST system. Now, I'm getting the following codes:
48 - MAF fail
41 - EST Open
43 - Knock sensor (probably because I broke the wire changing a spark plug)
18 - Injector something or another
Can I tune these out? At least enough to pass safety?
TIA.
Old Dec 12, 2006 | 10:51 AM
O J's Avatar
O J
And it looks like the answer is yes. Bryan at PCMForLess says he can hook me up.
Old Dec 12, 2006 | 12:00 PM
Do they actually hook up to an OBD-I PCM and read the codes as part of the emissions/safety check? I thought that was only used for OBDII.
I run the stock ECM in parallel with a MoTeC, and simply cut the wire for the SES bulb.
Old Dec 12, 2006 | 01:45 PM
O J's Avatar
O J
I was under the impression that they did. At least my mechanic said that if we couldn't connect at all (which was a previous problem) we couldn't pass.
Dec 1, 2016 05:37 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
