fuel line/block trouble ....HELP..please
I was changing some gaskets over the weekend and when I was able to get everything back together except one thing. The fuel rail on my 3.4 and the injectors are in place but I can not get the fuel lines back into the fuel block. There are two O-rings inside the fuel block and I keep trying to push the lines in but they won't go in. I took the rings out and the lines aren't in the fuel block tight enough.
Does anyone have an idea on how to get these lines in?
Any help would be appreciated.
Shaun
Shaun
Make sure you are lined up as straight as possible with the f.block and you have to have all the o-rings on it or in it. Try a light coat of some type of lubricant, grease or something pretty thick wont take much on your o-rings. Hope that helps
armedtrigger
Feb 24, 2015 08:30 PM
