Bad fuel pump?
Old Nov 12, 2006 | 01:51 AM
jah1542's Avatar
Bad fuel pump?
I think my fuel pump is going out, and I had a friend of mine who is a mechanic look at it. One thing he suggested is that I hook up an ampmeter to the fuel pump relay fuse whenever the car started acting up, and see how many amps the fuel pump was pulling. He said that it was a new technique they had been using at the dealership where he worked to daignose failing fuel pumps. He told me that if mine was pulling any more than 5.5 amps, it was probably on its way out. Over the last few weeks, I've gotten readings anywhere from 5.6 amps all they way up to 6.03 amps while the pump is priming the lines.
Has anybody ever heard of this method to diagnose a bad pump? Is 6 amps an indicator of a dying pump?
Old Nov 12, 2006 | 01:55 AM
lt11997's Avatar
I do the same thing at work. Last week I did a fuel pump on a ford ranger that was pulling 27 amps. 6 amps is kind of boderline, I would let it go for awhile and see if it gets worse.
Old Nov 12, 2006 | 05:10 AM
CALL911's Avatar
Sounds like a good way to diagnos it. Generally speaking, other possible signs the fuel pump is going bad, is the car will have trouble starting, and your fuel pressure will start to die down.
Old Nov 12, 2006 | 08:01 PM
jah1542's Avatar
Thanks for the input. I'll let it go for a while longer and recheck the plugs, injectors and such again. Maybe I missed something.
Old Nov 25, 2006 | 11:23 PM
DAdkins23's Avatar
What are the problems you are having with the car to make you think the fuel pump is going out?
-Dax
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
