gas tank
Old Oct 16, 2006 | 03:34 AM
Daniel6718's Avatar
gas tank
can you put a ls1 gas tank and pump into a lt1 car without modifications? plug and play? will the fuel pressure be a problem? or is that computer controaled? just need some info...friend needs a walbrough pump, i need some weight, thinking about selling him my stuff and buying a ls1tank and wabrough kit
Old Oct 16, 2006 | 11:00 AM
Severous01's Avatar
Re: gas tank
the 01+ units are light weight plastic. you'll have to cut the pigtail off the new one and put the lt1 pigtail back on...other than that you'll jsut have a better fuel pump
Old Oct 16, 2006 | 01:19 PM
LT1 POWR's Avatar
Re: gas tank
And 1.3 more gallons if you get a 99+.
Old Oct 17, 2006 | 07:29 AM
Daniel6718's Avatar
Re: gas tank
is that all...anyone else?
Old Oct 17, 2006 | 10:42 AM
LT1BRN's Avatar
Re: gas tank
what are the weight savings?
Old Oct 17, 2006 | 11:06 AM
Re: gas tank
Isn't the LS1 fuel system dead ended (no return line) with pressure control integral with the in-tank pump? Definitely not compatible with an LT1 and its recirculated system.
Old Oct 17, 2006 | 09:15 PM
Daniel6718's Avatar
Re: gas tank
i think the 98 is the ojnly non return style...some people have done the swap...just looking for info..
Old Oct 18, 2006 | 08:37 AM
01Z's Avatar
01Z
Re: gas tank
I can take a look but I'm pretty sure my 01 doesn't have a return system. Also, I did some checking a while back and I thought the fuel pump access ring location was different front to back at the center of the tank from the LT1 to LS1 years.
Old Oct 18, 2006 | 09:02 PM
Daniel6718's Avatar
Re: gas tank
thank
lmk
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
