Vortech S-trim
Old Sep 25, 2006 | 09:26 PM
blown69nova's Avatar
Vortech S-trim
I am looking for a streetable and relatively quiet supercharger, but I want enough power to go 10's.
I have a gen 1 small block 383 with forged bottom end, 8:1 comp, Trick flow 195 heads and a Comp xe 224/236 .573/.593 116lsa cam single plane efi intake with custom elbow and 75mm t/b. I'm using a n Electromotive tec2 and either 55 or 72 lb inj.
I would like to know what kind of power/times guys have made wit an s-trim.
Thanks, Steve
Old Sep 25, 2006 | 10:30 PM
bowtiepwr's Avatar
Re: Vortech S-trim
Thanks, Steve
>go with the T-trim not quiet but alot of power I wish I went with the YSi-trim off the bat.
Old Sep 25, 2006 | 10:36 PM
Re: Vortech S-trim
Anyone else?
Old Sep 26, 2006 | 06:57 AM
Eric@Victory Racing's Avatar
Re: Vortech S-trim
I also say the T-Trim is a better choice. It is a little louder but the ability for more power makes up for that.
Old Sep 26, 2006 | 07:26 AM
bowtiepwr's Avatar
Re: Vortech S-trim
>I just noticed that he has a D1SC so going to a T-trim is probably the same power. I think he wants to go stealthy
is that a good blower cam? 116Lsa?
Old Sep 26, 2006 | 12:34 PM
roguedriver's Avatar
Re: Vortech S-trim
I would agree with the other guys and go with at least a T-Trim. I just converted from an S to a T on my setup and am glad i did. I think i was working that S-trim. And as far as my experience with noise, the T-trim i have now is no louder then the S-trim i had.
Ken R.
Old Sep 26, 2006 | 02:49 PM
TransAm396's Avatar
Re: Vortech S-trim
stealthy with a T-trim or D-1??? lol what are you gonna say?? "oh that noise?? ehh just a bunch of screaming chickens under the hood thats all"??
Old Sep 26, 2006 | 02:52 PM
bowtiepwr's Avatar
Re: Vortech S-trim
>No I meant going stealthy with a S-trim quiet model. The noise is from the louder models i.e. T-trim, D1SC, etc.
Old Sep 26, 2006 | 04:53 PM
Re: Vortech S-trim
My d1sc and mondo bypass (to atmosphere) is REAL LOUD! I don't know if I care so much about stealthy as I do my sanity while cruising. The reason for looking toward Vortech is the bad luck I've had with my Procharger. My bro has an s-trim on his stang with 10k plus miles and it has performed flawlessly.
The 116 lsa cam seems to work well for me, I have about 15" vac at idle and the car went 11.49 @120mph with an f'd-up motor and 10psi last year. This year with a new motor and 15psi it feels great but I'm running out of injector (55lb), so I am trying to run a staged setup with 4 extra 30lb injectors. I had to send the blower back to ATI before I could tune it though.
Steve
Old Sep 26, 2006 | 10:37 PM
engineermike's Avatar
Re: Vortech S-trim
LJ ran 9.9x at 140 in a full weight LT1 car with a Vortech S-trim at 12 psi.
Old Sep 27, 2006 | 04:21 AM
bowtiepwr's Avatar
Re: Vortech S-trim
>then with a T-trim he should be able to run sub 9.0's
Old Sep 27, 2006 | 05:43 AM
rskrause's Avatar
Re: Vortech S-trim
How much does the car weigh? An S-trim is going to make mid 500's rwhp depending on drivetrain losses (manny tranny vs. auto, converter stall, etc.). If the car is light you could certainly see 10's or even high nines. But in terms of running a number, a lot depends on how well the car is set up for the drags. I've got a buddy with a 346SBF and an S-trim in his Mustang running 9.80's. But the car weighs only 3,200lbs, has a Lenco and decent suspension, etc. When I had an S-trim, I couldn't break into the 10's without N2O, but my car weighs over 4,000lbs with driver and does not have a drag type suspension.
Anyway, like I said, expect rwhp in the mid 500's or even 600 if everything else is optimized and figure your potential performance from there based on weight, traction, etc.
Rich
Old Sep 27, 2006 | 06:00 AM
Re: Vortech S-trim
I don't think the T-trim is that much better than the S-trim.
Old Sep 27, 2006 | 11:32 AM
rskrause's Avatar
Re: Vortech S-trim
S-trim = 1,000cfm ~650hp*
T-trim = 1,200cfm ~800hp*
*POTENTIAL engine (flywheel) hp. I am currently running a Procharger F1 (1500cfm) and making ~700rwhp (through a loose converter) without the N20. Figuring ~20% loss, that's about 900hp. At least 100 shy of the theoretical maximum.
Rich
Old Sep 27, 2006 | 12:26 PM
Re: Vortech S-trim
The compressor cfm is based on some boost level. Obviously, the more air the engine flows, the lower the boost will be, the higher the total flow will be. LJ's 140 mph at ~3750 lb indicates nearly 800 fwhp from an S-trim. Conversely, I was only able to run 133 mph at the same weight with a T-trim running the same pulley ratio as he was. That indicates I was only making about 680 fwhp.
