oil pan gasket sealing?
Old Sep 17, 2006 | 02:30 PM
Wishmaster's Avatar
hey, you guys using a 1 peice gasket...when you put it on did you use anything with it or just put it on dry? the motor is on an engine stand and I just put a little RTV on the ends of the timing cover.....I just want to make sure this thing doesnt leak once I get it in the car....so should I take it off and put any RTV anywhere else on the gasket?
Old Sep 17, 2006 | 03:55 PM
Dave89IROC's Avatar
Re: oil pan gasket sealing?
I put RTV at the corners of the front cover, and at the rear ro rhe rear seal housing(1 prm) / rear cap(2 prms)
Old Sep 17, 2006 | 04:18 PM
Wishmaster's Avatar
I have a 2 PRM....are the 1 piece oil pan gaskets **** to leak?...in those places?..should I also put RTV on each bolt? or does that not matter?
Old Sep 19, 2006 | 01:24 PM
85_305's Avatar
I used RTV all around and I have not had one leaking problem whatsoever. No need to put rtv on the bolts though.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
SergheiS
Apr 26, 2015 08:15 PM
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
