Code 23
Old Nov 13, 2002 | 04:10 PM
augi's Avatar
Code 23
I have a 94 Formula and every once and away the SES light comes on and freescan shows code 23 something about the MAT sensor. Can someone please give my more informative about what it means and what to check out? The only mods I have is a custom CAI and Hooker Lts.
Thanks
Old Nov 15, 2002 | 02:29 PM
aboadnan's Avatar
It is maifold air temprture, may be when you put the CAI you
didn't hook up the sensoror you have open circuit.
Old Nov 15, 2002 | 03:51 PM
augi's Avatar
Where is to sensor at? If it is unpluged wouldn't the light be on all the time?
Thanks
Old Nov 16, 2002 | 12:20 AM
DTC 23 sets when the PCM sees an irrationally low inlet air temp. That generally means excessively high resistance in the circuit. You either have a broken wire, or a bent pin on the plug that is making intermittent contact. Or possibly a faulty sensor.
The sensor is located in the rubber inlet bellows.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
