why does our stock fog light crack or break?
Old Aug 20, 2006 | 04:41 PM
Fbody1's Avatar
will they do this if you use a higher wattage bulb? or from getting old? is there any aftermarket lights that fit that kinda look like stock?
Old Aug 20, 2006 | 08:24 PM
Re: why does our stock fog light crack or break?
Please post in the correct forum. This belongs in "General F-Body Tech.....", not in "LT1/LT4 Engine Tech".
Moving.....
Old Aug 20, 2006 | 09:42 PM
shoebox's Avatar
Mostly, the lenses crack from foreign body impact.
Old Aug 21, 2006 | 01:59 PM
Bud M's Avatar
Replace them with Hella FF75s, they are a huge improvement in brightness.
Old Sep 13, 2006 | 07:28 PM
Fbody1's Avatar
Ok so now I have some hella FF75 fog lights, how did you mount yours.I searched and seen that you(BUD M) made some brackets that were triangler in shape .I need some pics or a drawing.can you help me out?
Old Sep 14, 2006 | 04:24 PM
lastZ's Avatar
had mine for 4 years never had one problem
Old Sep 14, 2006 | 05:03 PM
NavyBlueFanatic's Avatar
I just put in 2 new fog lamp bulbs, I have a T/A though....
Old Sep 16, 2006 | 07:23 PM
pearlpurple's Avatar
The ones on my 93Z were bought from Autozone come with 55 watt bulbs, I upgraded to 100 watt bulbs once they started to burn out. They fit right in the same location and look almost stock.
Old Oct 22, 2006 | 10:17 AM
jjminch's Avatar
I need to replace mine. Can I get some pics of how they mounted? Or is there a certain mounting bracket that I need to look for when I purchase them? DId you just wire into the stock harness?
Old Oct 22, 2006 | 01:01 PM
OBE1 95Z28's Avatar
Do the Hella FF75s run off the stock harness, or does the harness need to be replaced?
Old Oct 22, 2006 | 01:44 PM
Z95m6's Avatar
It depends on what wattage bulbs you run. On my fogs i'm running 55 watt bulbs so i'm running the stock harness. On my headlights i'm running 100 watt bulbs so i put in supplied Hella harness. Also for people with the Hella Foglights you might want to spend the extra money on getting the clear plastic lense protectors. They snap right on and will save you from buying new lights if your lense cracks.
Old Oct 23, 2006 | 09:39 AM
OBE1 95Z28's Avatar
Thanks for the reply! Hella sells 2 styles, the fog and running lights. Any input on which pattern works best for our Camaros?
Old Oct 23, 2006 | 10:02 AM
jjminch's Avatar
Need more pics
Old Oct 23, 2006 | 11:34 AM
Z95m6's Avatar
Running lights for headlights and foglights for the fogs. The fogs have a very wide horizontal pattern but don't go out very far, the driving lights are like little spot lights. They have a very tight light pattern.
Old Oct 23, 2006 | 12:12 PM
Bud M's Avatar
Sorry, no pics of the brackets but figuring them out isn't very hard. Remove the stock lights. Get a piece of cardboard and cut to about 6 in. square. Use the stock driving lamp bracket for a template for the 2 holes that mount to the car. Attach it to the car. Put the Hella lamp in place and mark where its bracket attaches to the mounting bracket. Put a hole there and attach the lamp. Test fit, adjust as necessary. When you are satisfied with the dimensions of your test bracket, duplicate it in aluminum. Use some that is thick enough to resist bending but not so thick that it is difficult to work. Something under .100 in. thick. You don't need to put any bends in it. Fine tune the height and strightness of the lamp with washers.
They come with a relay and wires so you can wire them straight from the battery power. Tap into power at the red plastic box near the battery and use the original power to open the relay. The lights come with instructions that show which relay connections go to what. I mounted my relay on the metal next to where the radiator overflow reservoir cap is. Get a package of 1/4" split wire tubing for a clean installation.
Fog lights are for fog. Driving lights are what you want.
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
