Problems with moser 9" and a lowered camaro.
Old Jul 30, 2006 | 05:28 PM
1 DWN CAM's Avatar
My 92 camaro is lowered with suspension techniques springs lowered about
2"1/4 all the way around. I have installed my moser 9" and spohn adj torque arm and everything seemed fine until I try'd to install my gas tank. There is about an inch of clearance between the pumpkin and the gas tank. If there is any compression on the suspension the pumpkin will compress into the gas tank. Is this the norm? Has anybody ran across this problem? Any idea's on a solution would be appreciated, i don't really want to start hacking on my body if I don't need to.
Old Jul 30, 2006 | 11:52 PM
1racerdude's Avatar
Re: Problems with moser 9" and a lowered camaro.
Here is what to do to fix it. I had the same problem and this is what I figured out to fix it
Old Jul 31, 2006 | 09:38 AM
1 DWN CAM's Avatar
WOW! how many gallons do you think you lost when you did that?
Old Jul 31, 2006 | 03:26 PM
1racerdude's Avatar
Maybe 3.
Ain't figuring on driving non stop to Las Angeles.
Old Jul 31, 2006 | 04:53 PM
1 DWN CAM's Avatar
Did you completely bottom out the suspension when you notched out the tank? Also how about the torque arm? any issues with that?
Old Jul 31, 2006 | 05:01 PM
1racerdude's Avatar
TA needed clearance on the left side of the tunnel and on the back side.
I put 3" snubber on the shocks to limit it's travel.
Old Jul 31, 2006 | 05:46 PM
1 DWN CAM's Avatar
For the torque Arm clearence did you cut into the body heatshield?
Old Jul 31, 2006 | 06:00 PM
1racerdude's Avatar
The drivers side had no heat shield . Ya also have to cut the cross bar that runs across the back of the back seat area.
Old Jul 31, 2006 | 09:25 PM
james007moore's Avatar
Originally Posted by 1racerdude
Maybe 3.
Hey 1racerdude, that response is "classic"......i laugh just thinking about it ! ! ! ! ! ! That may go down as the best response in the history of CZ28.com
james
Old Jul 31, 2006 | 09:33 PM
1racerdude's Avatar
Classic comment from an old fart.
I try to keep a sense of humor 'bout things. Makes the day better.
Old Aug 1, 2006 | 09:24 AM
1 DWN CAM's Avatar
Thanks for all the info, it's been a lot of help.
Old Aug 2, 2006 | 09:41 PM
FireChicken1995's Avatar
i know that on my T/A with a 12 bolt and girdle it hits that bar above the panhard rod.... not that it matters to you're problem..... just wanted to say you have one of the most kick *** 3rd gens iv ever seen that is all
Old Aug 3, 2006 | 09:31 AM
1 DWN CAM's Avatar
Thanks for the kind words!
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jan 31, 2015 07:29 PM
ddr698
Jan 9, 2015 10:05 AM
bernie1951
Dec 10, 2014 10:03 AM
