piolet bearing
Old Jul 26, 2006 | 07:12 AM
Camaro_Boy's Avatar
piolet bearing
hey guys. its dumb to ask however if put in incorrectly. the bearing can seize.. what is the right way to put it in. so you can see the bearing when looking at it? the splines of the bearing? or so you see only the metal. i believe it only makes sense to how the main part of the bearing showing..
here is the way i think you should be able to see it when its in the engine...
http://www.keislerauto.com/gm/transm...o/image004.jpg
is this correct?
Douglas
Old Jul 27, 2006 | 09:26 AM
Camaro_Boy's Avatar
Re: piolet bearing
all sorted out.. the bearing part should be showing... thanks anywayz
Old Aug 3, 2006 | 09:41 AM
Camaro B4C's Avatar
Re: piolet bearing
I just bought a roller pilot bushing/bearing yesterday and I was curious of the same thing. Per the directions the flat surface where the bearings are should be towards the crank and the smoothed rounded surface towards the trans to accept the shaft. Hopefully I'm not too late.
Old Aug 3, 2006 | 09:54 AM
Camaro_Boy's Avatar
Re: piolet bearing
yup you got it. i put mine in incorrect. it never came with instructions.. i had to rip it back out what a job
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
