headlights grinding
Old Jul 27, 2006 | 01:31 PM
diabeticfirebird's Avatar
Unhappy headlights grinding
I have a 99 firebird v6 and everytime u put the lights down they make this grinding noise as if there trying to go down further but cant....any suggestions to the problem....and how hard is it to fix?
THX!
Old Jul 27, 2006 | 01:39 PM
Grims's Avatar
Re: headlights grinding
Search next time, the plastic gear inside the motor has failed. Do a search for 'headlight fix' and you will see the many different ways to fix it.
btw, this isn't engine related.
Old Mar 21, 2007 | 12:40 PM
CALL911's Avatar
I know this is ancient. But if you haven't found the answer yet, it is because you have bad headlight gears, and they need replaced. Check out http://www.bfranker.badz28.com/headl...htm#MetalGuide
You can get new brass gears from Brent Franker there which cost a lot less than getting new ones that will probably go bad again sometime. Also included on the website is a good "how to" installation guide.
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
