Does this ET and trap speed seem off?
Old Nov 11, 2002 | 07:42 AM
sandmanljs's Avatar
Its not me, but I guy I raced last friday(I dont know him). His ET was 15.757 and a trap of 100.64. Does that mph seem a little high for the et? I think it was some kinda of import. Thanks.
Old Nov 11, 2002 | 09:41 AM
CANTONRACER's Avatar
traction or lower rpm tuning issues.
Could be the timing lights error.
Old Nov 11, 2002 | 07:40 PM
Stephen 87 IROC's Avatar
Probably just geared wrong. When I was using a 383 stroker and had 3.27 gears in the diff I was running 12.0 at 117 mph. Usually 12.0 is in the 108-109 mph range. I ran out of track well before I ran out of rpm. Geared properly it should have run 11.6's.
Chances are that car is the same. 100 mph should be good for a low 13 or high 12 second pass if the gearing is set up better so the car crosses the finish line at red line. There's also a possibility that it has so much power and no traction that it just spun through the lower gears and lost the ET from wheel spin.
Old Nov 13, 2002 | 11:31 AM
A Small 427's Avatar
most likely he didnt hook up, esecially if its FWD......what was his 60'?
ZZed
Sep 10, 2002 04:13 PM
jp2002ls1
Aug 30, 2002 08:18 PM
z28kid93
Aug 22, 2002 04:40 PM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
