Engine Builder's Notebook
Old Jul 12, 2006 | 05:54 PM
KAT Automotive's Avatar
What do you use to log everything about the engines you build? Do you have software or paper forms? There's a ton of measurements that need to be recorded. So what do you use?
I posted in the Advanced Tech because usually only the advanced builder keeps a notebook of EVERY spec of their engine.
Old Jul 12, 2006 | 06:37 PM
Kevin Blown 95 TA's Avatar
Re: Engine Builder's Notebook
I made an excel spreadsheet this last time. I also have all the teardown & rebuild pics organized in a folder with subfolders.
Old Jul 12, 2006 | 07:06 PM
Would you be willing to share your spreadsheet?
TIA
Old Jul 12, 2006 | 07:52 PM
MachinistOne's Avatar
I have a buildsheet that I can post on here, will do tomorrow.
Old Jul 12, 2006 | 10:28 PM
rskrause's Avatar
I just write everything down. Some sort of organized format is a good idea. Never really thought of it in the past though.
Rich
Old Jul 13, 2006 | 12:44 AM
SStrokerAce's Avatar
Dam, I just do everything in my head. I can't sleep at night if it's not right so I have to do it right!!!!!!
Seriously writing it down is a dam good idea, there are a ton of clearances you need to check just make sure you check them all and they are in spec. Guys who do it all the time know what that part should be so they can be a little more lax about it, but then again if you can't name off all the parts in every motor you build you NEED A SPEC SHEET.
Bret
Old Jul 13, 2006 | 09:45 AM
Victory Racing's Avatar
I use a legal pad and write everything down, during blueprinting I typically go through 2-3 different combinations of bearings before I find what I like. So its numbers everywhere.
Afterward I write all the numbers down in an organized build book that I supply the customer upon request. Most aren't interested but some are, so we do that for them. I also keep a copy with my records, attach cam card, piston spec card, balance card and anything else critical to that assembly. I also have a page on the build book for notes to record anything specific to that build or a certain customers needs or how a cam was timed etc.
Its a lot of writing but I can't see doing it any other way.
Old Jul 13, 2006 | 10:47 AM
TIA
I'll see if I can put it on my web site tonight and make a link to it.
Old Jul 13, 2006 | 05:52 PM
OK here it is. Some of the clearance fields are calculated, some are not. Just check the cells before you put a number in there if not sure.
Right click and do a "save as" to download.
http://home.earthlink.net/~kwkrahl/E...asurements.xls
Old Jul 19, 2006 | 09:31 PM
quickSS's Avatar
Kevin! that is a sweet spread sheet. Although I don't have MS excel I'm going to get it and use this very well written and organized build sheet.
thanks!!!
karl ellwein
Ellwein Engines
Old Jul 20, 2006 | 09:11 AM
If it helps you keep things organized than it is a good sheet. Thats what really matters here.
Good sheet and thanks for sharing it.
Old Jul 25, 2006 | 02:42 PM
Dave88LX's Avatar
Here check this .xls out:
It says 351W; I was using it for my Mustang, but, just name it whatever.
2 tabs on the bottom.
You'll have to change a couple things around with the rod widths since Chevy shares different ones.
http://paradox.shacknet.nu/dave88lx/...0Blueprint.xls
Roadie
Feb 16, 2015 10:34 AM
Chevyguy358
Jan 28, 2015 08:04 PM
NewsBot
Dec 17, 2014 02:50 PM
Bearmans
Dec 3, 2014 05:28 AM
