SFC questions
Old May 10, 2006 | 02:57 PM
BarneyMobile's Avatar
SFC questions
I need to kno what are the best weld in SFC, I was looking into BMR and UMI. I kinda like BMR alittle more. I also need to kno whats better to get, Boxed or tubeular SFC. Thanks!
Old May 10, 2006 | 07:38 PM
2000GTP's Avatar
Re: SFC questions
The tubular design will offer plenty of strength and will not sacrifice ground clearance as some of the boxed designs. Which UMI connectors are you looking at... the 2 point or the 3 point? If you are looking at the 2 point, there is not much of a difference between those or the BMR SFCs. The UMI 2 points are most likely a little cheaper then the BMRs though.
Old May 10, 2006 | 07:40 PM
SantaCruz163's Avatar
Re: SFC questions
If you ever plan on lowering the car go with tubular which will definitely work even if you don't lower it. But if your 100% sure you'll never lower the car get boxed; they are alittle stronger, but hang down about 1".
Old May 10, 2006 | 08:07 PM
Steve0's Avatar
Re: SFC questions
I have the UMI boxed SFCs. They are of good quality and do not hurt ground clearance. You can see them under the car, but my exhaust hangs lower than the SFC's.
I went with boxed for the sole reason that if I wanted, I can now an entire side of the car with one jack.
Old May 11, 2006 | 05:38 PM
Z95m6's Avatar
Re: SFC questions
You can do that with the tubulars as well.
Old May 11, 2006 | 08:06 PM
mook99TA's Avatar
Re: SFC questions
GO with UMI's they are cheaper and they are pretty much the exact same thing as the BMR's. I went with Tubular and unless you are over 500 or 600HP and TQ its not gonna matter.
87Aerocoupe
Jan 10, 2015 07:27 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
slocody
Feb 10, 2003 01:04 PM
rje
Sep 9, 2002 12:35 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
