STB installation
Old May 10, 2006 | 10:02 AM
95GRNZ's Avatar
Question STB installation
Okay... Probably a dumb question, but I'll ask anyway...
I just bought a used BMR STB and it didn't come with any installation instructions. So..., is there anything more to it than just removing the nuts from the top of the struts, installing the STB and tightening the nuts back on?
Thanks!
TS
Old May 10, 2006 | 02:20 PM
Brandon94Z28's Avatar
Re: STB installation
nope that's it.
Brandon
Old May 10, 2006 | 02:34 PM
One possible problem is the fact that the studs from the upper spring seats, that you need to slide the STB over, are not vertical. As a result, it may appear impossible to fit the brace over the studs... one side will fit, the other won't. I had to loosen the two bolts on one shock tower, in addition to the two studs. Then I jacked the front end, and pulled the wheel down so the studs retracted into the fender. Then you put the STB over the holes, and let the studs pop up into the holes.
Old May 10, 2006 | 03:03 PM
OBE1 95Z28's Avatar
From BMR's site:
http://bmrfabrication.com/instructions/stb001.htm
Old May 10, 2006 | 09:14 PM
95GRNZ's Avatar
Thanks guys! No problems with the installation: removed the nuts, placed the STB over the bolts, tightened the nuts, done.
Originally Posted by OBE1 95Z28
I took a quick look at their website, but couldn't find that... Duh...
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Don 97 SS
Jul 11, 2005 08:50 AM
lbrowne
Aug 22, 2002 06:21 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
