rpm - tach wierd issue 7 k bounce!?@
Old May 3, 2006 | 02:58 AM
Radd's Avatar
hooked up my new 150 wet shot kit on the new motor. set the jets up for a 100 shot to test it. gave it a few runs and the rpms on the tach bounced off of 7 k but the motor was no where near that. I noticed after i got off the shot the rpms where back to where they were supose to be. i hooked up a WOT switch, On off switch and a momentary switch. i took power off the cig lighter for the On Off switch and the momentary switch. I used the ground block and power block up by the battery for the relay to the selonoids. What would cause the rpms to read so erraticly?
Old May 3, 2006 | 10:09 AM
Radd's Avatar
Re: rpm - tach wierd issue 7 k bounce!?@
anyone have a idea?
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
