TC, WOT tuning a/f - thru the MAF tables right?
Old Apr 16, 2006 | 07:33 PM
DarkHorse's Avatar
In Tunercat, the best place to adjust the A/F ratio would be in the 4 MAF tables correct?
I'm currently at 10.4:1 and would like to get back to at least 11.7-12.0 area. Using Datamaster as logs and the dyno - what's a good % to take out of the MAF to achieve 11.7-12.0 air/fuel?
Old Apr 16, 2006 | 07:59 PM
mattbailey's Avatar
Re: TC, WOT tuning a/f - thru the MAF tables right?
I always take out -1.025% of the Maf tables and then datalog to check the changes.
Old Apr 16, 2006 | 08:00 PM
Jon A's Avatar
You're much better off changing the PE table--"% To Change Fuel/Air vs. RPM at WOT."
Old Apr 16, 2006 | 10:18 PM
DarkHorse's Avatar
Change from here then? Do I need to check/monitor my BLM's at all?
Thanks
Old Apr 18, 2006 | 11:56 AM
evilundisguised's Avatar
Thanks
The most accurate way would be to make a change, take wideband readings, analyze the efffect, repeat if necessary. At WOT, your narrowband sensors are ignored. You are talking about WOT tuning, correct?
Dec 1, 2016 05:37 PM
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
jayblev95
Jan 20, 2015 01:30 PM
