please help senser losing vacume
Old Apr 9, 2006 | 03:35 PM
greenz2895's Avatar
Unhappy please help senser losing vacume
my car is running like crap.so i heard a vacume leak so i looked for it and found one but its comming from the bottom of a senser.i have no clue what the senser is.its back on the intake on the drivers side near the number 5 and number 7 injecters.it as two vac lines going to it.so does this mean its bad or is it made to do that
Old Apr 9, 2006 | 10:26 PM
Re: please help senser losing vacume
Do you possibly mean the EGR vacuum solenoid? Its behind the #7 injector, but there's nothing located between #5 and #7. It shouldn't be leaking. Check the hoses.
I'm assuming from you screen name that you are talking about a 95 LT1.... you might want to add a "signature" with basic info about your car like year, trans type, and major mods, so people can help you easier.
This photo on Shoebox's page shows the EGR components. If its not the EGR solenoid that you are talking about, maybe you could explain where it is in the photo.
http://shbox.com/1/egr1.jpg
Old Apr 10, 2006 | 06:43 AM
greenz2895's Avatar
thats the one its leaking vacume out the bottom.i had my egr valve removed from the car and computer.
Old Apr 10, 2006 | 07:20 AM
If you don't have an EGR valve, you don't need any of the other parts. Didn't you plug the vacuum lines when you removed the EGR valve? The vacuum lines and the solenoid can be removed. Just put a vacuum cap over the nipple on the side of the intake manifold.
When they did the PCM, did they also "program out" the diagnostic for the solenoid? If not, you will have to put a resistor in the harness connector to prevent a code for the missing solenoid.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
surreybrad
Aug 10, 2015 09:34 AM
alex5366
Jun 14, 2015 10:27 PM
Amshnock
14
Jan 18, 2015 11:47 AM
