driveshaft question
Old Mar 31, 2006 | 09:43 AM
myslowcamaro's Avatar
driveshaft question
after seeing krause's sticky, went to some of the links. is carbon fiber really that much stronger than the metal composites? golf clubs i can see, but anytime i used c.f in a torque scenario for machines, it snaps in seconds. anyone have experience with these shafts?
Old Mar 31, 2006 | 02:14 PM
jonathan_abilene's Avatar
Re: driveshaft question
not sure, but I think it will hold like ~ 600 rwhp
Old Mar 31, 2006 | 02:18 PM
97FormulaWS-6's Avatar
I haven't heard much good about the CF shafts to be honest. Most of them I've heard have some serious issues where the ends are bonded to the CF shaft portion.
Personally if you're making any serious HP, I'd go with something more reliable like a Denny's NR shaft; guarenteed against shaft breakage for life.
Old Mar 31, 2006 | 03:52 PM
rskrause's Avatar
Serious cars use good chromemoly shafts. Denny's, Spohn, and Dynotech are all excellent sources.
Rich
Old Apr 1, 2006 | 12:23 AM
I had an ACPT CF DS that failed (metal input section separated from CF tube) under part load with the computer tuned only for enough power to drive the car from the engine shop to a body shop. I can't imagine what kind of problems I would have had it it had let go at 800HP on the chassis dyno.....
That sort of turned me off on CF. It also turned the shop that built my engine off on CF, but when they needed a DS for their 7.0-second Pro5.0 car, Mark Williams told them that due to the length and the 9,000+RPM redline, the only material they could use that would meet the critical frequency requirements was CF..... so their 7.0-sec car ran a full season with a Mark Williams CF setup, with no problems. I guess it can be done by some companies, but ACPT didn't do too well.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
