paintin my car...
Old Mar 28, 2006 | 10:51 PM
DiabloGT's Avatar
paintin my car...
im painting it candy black, so i get the metallic basecoat, candy concentrate, black primer, lacquer thinner, clear coat, and obviously the sandpapers, etc. my friend said after putting on 3 layers of basecoat you let it dry for 2-3 days then sand it with around 2000 grit and then clearcoat it, is that true? please help
thanks
Old Mar 29, 2006 | 12:33 AM
Silvershark's Avatar
Re: paintin my car...
I would not recommend sanding the base coat. This could put imperfections in your base and cause it to be really noticable when you go to put down the clear...
I would suggest taking a sharpie, marking all areas that have divets or holes and then take a orbital or DA sander to those spots first. Take some filler and hardener and fill those spots. block sand them smooth with 220 grit. I would then suggest primering over those spots and block sanding with 220 grit again. I would then primer the whole car, then apply a guide coat over it. Let it dry for atleast 6 hours and then block sand with an agressive 180 grit. Apply another primer coat and sand with a 320 grit. I would then wait atleast a day and then apply your base coat. Let it flash to the recommended time and then apply another coat, and then one last coat. I would then wait a full day and apply your clear, wait the recommended flash times. Make sure you do 4 coats of clear. I would then go ahead and wetsand the clear with 1000 grit, then 1500 grit, then 2000 grit. I would then get a polisher and some 3m compound and buff the car.
It sounds like a lot of work, but you dont want to skimp on the prep work.
Old Mar 29, 2006 | 06:30 AM
fasteddie94's Avatar
with black you should go finer than 320. Black shows everything. Final sand your primer with 600 just to be on the safe side. I did and mine turned out very slick.
Old Mar 29, 2006 | 11:51 AM
I should have specified... I would go with a high build 2k primer. These fill scratches from 80grit. So there really is no need to go higher than 320 grit. But to each their own.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
JeffK95Z
Pacific
11
Apr 18, 2003 12:54 PM
ProudPony
11
Mar 25, 2003 06:38 PM
vinnyxgunz
Jan 31, 2003 04:05 PM
DeathBuzzz
Jul 12, 2002 06:31 PM
