OMG: There is a point where street tires just dont work.
Old Mar 25, 2006 | 12:29 AM
jsetzer's Avatar
Finally got the new motor to the track. Street tires and did not have the bottle hooked up.
Some how ran a 15.0 @108, then a 13.3 @ 112 with a 2.5 60'
I know it will run awesome once I get it to the ground. High 11s and 115mph+ are within reach I am sure.
I only got a few passes before I threw a belt and shredded some plug wires on the pass side.
WOT in 1st or second is impossible. It breaks loose in 3rd and still chirps 4th hard.
Our track is concrete so maybe thats part of it too
Guess its time to give up on street tires.
New motor if anyone cares:
Eagle 357 assymbly.
5.7" h beams
srp -5cc pistons
eagle 3.50" crank
gm 847
heads ported by local shop, valve job, bigger valves
ported intake
electric water pump
2.5" duals with flowmaster 40 series on each side
Old Mar 29, 2006 | 03:28 PM
maverickmechanic's Avatar
Re: OMG: There is a point where street tires just dont work.
try doin what the nostalgiaracers do... running on older style bias ply tires
Old Mar 29, 2006 | 04:18 PM
2000GTP's Avatar
Put on some real tires and see what she can do.
Old Apr 6, 2006 | 12:54 PM
Alpinetypers's Avatar
I had the same thing with my street tires. It is hard for them to provide proper traction with 375 rwhp.
I think I am going to pick up a set of MT slicks for the next time I hit the track.
Old Apr 10, 2006 | 09:46 PM
Guido67SS's Avatar
Cool now it's time to find the next weekest link ... bwahahahaha!
All kidding aside, check the u joints. Makes sure everything is tight. If you hook with the tires something will break especailly with the 4 spd but I am here to tell you it is fun.
Old Apr 10, 2006 | 10:36 PM
Javier97Z28's Avatar
Street tires don't hook at stock power levels.. not sure why you'd think they'd hook with that much oomph in front of 'em
Old Apr 11, 2006 | 03:32 AM
rskrause's Avatar
You are now on the road to perdition. Once you get good tires on it, all the other weak points will be exposed. Stuff like borken trannies and rear ends, twisted torque arms, driveshafts, axles, and so on.
Have fun and enjoy the ride!
Rich
Old Apr 12, 2006 | 03:35 PM
Cmr0z28's Avatar
6spd ftw
Mar 15, 2015 07:01 PM
Ken Cemo
Feb 13, 2015 08:37 AM
Ken Cemo
Jan 27, 2015 08:45 AM
twistedwedge
Jul 27, 2002 01:54 PM
Redbird
Jul 20, 2002 06:08 AM
