redline on lt1
Old Mar 22, 2006 | 03:55 PM
bringBackCamaro's Avatar
redline on lt1
Where is the redline on an LT1 M6
Ive been shifting at 5,000 rpm
but i think its killing my times
how high should i be shifting
~5,200 ?
Old Mar 22, 2006 | 05:47 PM
Sean94Z's Avatar
Re: redline on lt1
Isn't there a redline on your Tach? Try 5800 and see how that works ..
Old Mar 22, 2006 | 06:13 PM
96flame's Avatar
Re: redline on lt1
I beleive the stock rev limiter is at 5800 rpms. I shifted at 5600 when the car was stock. Also remember the dash tach isn't very accurate. I hooked up a shift light for more accurate shift rpms.
Old Mar 23, 2006 | 09:36 AM
Re: redline on lt1
is there such thing as a shift light that you dont have to also install a tach for? I dont run a MSD or anything like that
Old Mar 26, 2006 | 12:46 AM
1BadZ95's Avatar
Re: redline on lt1
5850
Old Mar 26, 2006 | 05:44 AM
2000slp2768's Avatar
Re: redline on lt1
several companys make stand alone shift lights. MSD for example has 2; one has a dial on the back you set for the shift point, the other uses their rpm pills.
Old Apr 1, 2006 | 11:14 AM
BradcTA's Avatar
Re: redline on lt1
At the track I ran mine up to 6200 a couple of times. I had LTs/TD so it still pulled hard up there...
Old Apr 1, 2006 | 05:46 PM
LT1Squirrel's Avatar
Re: redline on lt1
i run first out to 6k and every shift at 58-59 after that by way of stock tach
bossco
Nov 29, 2014 10:18 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
simple
Aug 11, 2002 11:56 AM
