alternator trouble with lt1 swap into 3rd gen
Old Mar 20, 2006 | 01:48 AM
93formula's Avatar
we swapped a 95 lt1/t56/stock pcm into a third gen, i think its a 90, anyways everythings is in and fired up however the alternator isnt charging, the battery keeps dieing, we tried three different alternators, same result, not charging.
is there something were missing????
Old Mar 20, 2006 | 02:39 AM
iansane's Avatar
Re: alternator trouble with lt1 swap into 3rd gen
Does the alt get the 12v signal to "turn on" when you start the car?
Old Mar 20, 2006 | 10:40 AM
93formula's Avatar
i dont know we didnt check to see, we got a local to redo the stock harness, what i recall is one wire to the battery and another to the gauge, ill double check.
Old Mar 24, 2006 | 05:19 PM
cronsformula350's Avatar
Theres a fuse, called "fan", if your fans aren't working either, thats a tell tale sign. Check the fuse, and see if its blown, if its blown, the computer never tells the alternator to start charging.
Old Mar 26, 2006 | 06:54 PM
Klortho's Avatar
There is one red wire in the wiring of the LT1 in either the Blue or White (can't remember offhand) that has to have a 470ohm 1watt resistor soldered inline and the other end connected to a 12v switched source. With out this, the alternator never gets the signal to start charging.
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
