members with telstars (15x8 5bs)
Old Feb 17, 2006 | 12:12 AM
Green G0blin's Avatar
did you have to grind your calipers? cus i have an ls1 and i might get some telstars, but, i dont want to grind, i heard you have to grind MORE than you do if you put prostars. i was thikning i might downgrade to lt1 rear calipers and rotors if i dont have to grind, or grind alot if i do that with the telstars? any help is appreciated! pics is much appreicated!
Old Feb 17, 2006 | 12:23 AM
Cmr0z28's Avatar
Re: members with telstars (15x8 5bs)
There's a local guy with a '95 Z28 on 15x8 (rear) Telstars, and he said he didn't have to grind anything.
Old Feb 17, 2006 | 01:11 AM
is his car lowered?
since the ones im looking at are only 5"bs, i wonder if its gonna rub my fender when i launch at the track? im cutting 1.7 60s now..wonder if it will rub cutting the tire? anyone have a dropped car running this setup?
Old Feb 17, 2006 | 09:51 AM
fastcamz28's Avatar
According to the articles in GMHP magazine regarding the '94 Grapes of Wrath Project car, the Telstars were a bolt-on w/o caliper grinding, front or rear. I purchased the exact set up for my '94 w/ oem calipers and have to use a spacer to prevent grinding the calipers on the front, backs fit fine! So, it must just depend on the car. I am disappointed that I have to use a front spacer because now I have to change wheel studs to meet NHRA/IHRA safety specs. My car is lowered via Eibach springs, but there is no fender rub in the back and I am running the same size wheel as you described. hope this helps!
Old Feb 17, 2006 | 11:10 AM
PLEASE post on the correct forum. "wheels" questions do not belong on LT1/LT4 Engine Tech. Moving to "Wheels and Tires".....
Old Feb 17, 2006 | 11:14 AM
Cmr0z28's Avatar
You shouldn't have any problems rubbing. I'm cutting 1.5s on stock suspension with 28" tires without any rub.
Old Feb 17, 2006 | 07:16 PM
My Iroc Z28's Avatar
I just finished reading over that same article.. I thought that was pretty interesting becasue i don't want to grind any of my calipers to get wheels to fit! Now my question is if it fits LT1 brakes will it fit LS1's? i have swapped my entire brake system from my 97 to a 00.
Old Feb 17, 2006 | 08:59 PM
DarkHorse's Avatar
No grinding at all with LT1 brakes.
My buddy and board member, CANTONRACER's, webpage with all the information you'll need:
http://www.geocities.com/jmaxnakron/..._TELSTARS.html
Old Feb 17, 2006 | 10:42 PM
lethal93ta's Avatar
they fit on my LT1 but there really close only about a 1/2 inche between the wheel and caliper. on the LS1 brakes I dont think thell fit with out grinding
Old Feb 22, 2006 | 01:16 PM
OutKast's Avatar
I didn't have to do any grinding when I put Telstars on my 94.....until I put new pads/rotors on the front. I'm guessing that most who haven't had to grind might run into this problem later on.
Pics are in the sig
Old Feb 23, 2006 | 05:54 PM
DarkHorse's Avatar
I have 15x8 Telstars on the way - with an LS1 rear i'm going to have a bunch of grinding to get these to fit.
Old Feb 23, 2006 | 07:31 PM
Let me know how much grinding you have to do.
Old Feb 25, 2006 | 09:22 PM
joeZ96's Avatar
Running 15x4/15x8 Telstars. No grinding whatsoever. I have heard too that it takes a lot of grinding to make them fit on an LS1.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
