Would these work as a turbo cam?
Old Feb 13, 2006 | 08:24 PM
94irocz's Avatar
here is a link to the cam in the new summit mag.
http://store.summitracing.com/defaul...=egnsearch.asp
here is the 210/218
how would these work under boost compared to the 224/236 .533 .555 114 cam I already have?
This is for a 355" 9.0:1 motor with a turbo in the t70-t76 range.
Thanks
Old Feb 13, 2006 | 08:34 PM
96m6lt1's Avatar
Re: Would these work as a turbo cam?
no cams showed up but i really like the cc305 with boost 1.6 rockers and bee hives or 987s
Old Feb 13, 2006 | 10:04 PM
Roadie's Avatar
Keep the 224/236 on a 114... I have that cam in a 383 that's getting a precision T76 Q-trim real soon.
engineermike put down 690ish at the wheels through an auto with that cam and a T76GTS... He told me not to bother changing cams.
Old Feb 14, 2006 | 09:20 PM
engineermike's Avatar
Of course, I agree with Roadie. Go with the T76 GTS and don't waste your money changing cams.
Old Feb 16, 2006 | 03:26 PM
RealQuick's Avatar
I bought a a custom SC cam from bret Bauer when I thought I was going to be putting a vortech on my 383. I then decided on a turbo setup and told Bret i would pay him to do a turbo grind. He said its not worth te money and that the SC cam would produce similar results.
Using an engine analzer software, I actually saw better numbers when using the SC cam then the turbo cam (that is just strictly changing cam specs only).
LeftoverChinese
Jan 14, 2024 03:03 PM
rideordie
Nov 5, 2019 04:52 PM
Dec 1, 2016 05:37 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
