making a stronger car
Old Feb 7, 2006 | 07:47 AM
94307's Avatar
I was thinking of adding a roll bar, but I don't want to lose the back seat (yes, it gets used, poor saps). Actually, my first thought was to seam welding, but I don't weld, and I be it would be expensive. I already have sub frame connectors (kbdd from a long time ago), but the car still needs alot more strength. Any ideas? Maybe take a welding class? Also, any cons to seam welding?
Old Feb 7, 2006 | 08:52 AM
aggiez28's Avatar
Re: making a stronger car
do you run the times needed to have a bar?
Old Feb 7, 2006 | 09:55 AM
OBE1 95Z28's Avatar
Why do you want more strength?
Old Feb 7, 2006 | 11:03 AM
Z28LT1_Just_Nasty's Avatar
You don't need one if you running above 11.99
Old Feb 7, 2006 | 09:24 PM
Z06Z28's Avatar
lol, I like your sig...sounds like my car.
Old Feb 8, 2006 | 02:53 AM
94307's Avatar
I am getting chasis flex that is now quite noticable. The car has lots of miles, so I expect that it is succumbing to all the abuse of 300k miles and lots of road courses has inflicted upon it. I mainly want to eliminate the anoying flex that I notice going over highways that are not smooth. It is most obvious in the seats, but I am going to remove them and check the tracks for play just to rule that out.
Old Feb 8, 2006 | 08:41 AM
Check the studs that hold the seats to the floor. They are tack welded to the upper sheet of steel in the floor pan. I had two of those rip loose from the floor pan at very low mileage.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
NewsBot
Dec 3, 2014 12:30 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
