pro chips
Old Jan 18, 2006 | 04:12 PM
jalb's Avatar
pro chips
whats the best chips to have,,i have been looking on ebay at some of the ones they have for under 40 bucks but are they good to use,, is it possible that using proformance chips can reduce the life of the trans/engine???
the choices i see are: the juice box,,,speed seeker,,,GorillaChipz
2000 Z28 All stock as far as i know
Old Jan 18, 2006 | 04:32 PM
Re: pro chips
There are no replaceable "chips" on your 2000 Z28. The PCM has a fixed chip, and needs to be flashed with program changes. You can get handheld programmers that will load canned programs, get software that allows you to program it yourself, go to a shop that has programming software, or get a "mail order" tuner to work up a program for you.
The "chips" you see on eBay are frequently little more than resistors that replace or are added to various sensors in an attempt to fool the PCM into producing a few extra HP. IMHO, they are generally worthless.
Old Jan 18, 2006 | 04:49 PM
JakeRobb's Avatar
Super Moderator
Re: pro chips
Mail order tunes are pretty popular around here. MadZ28 and PCMForLess are both supporting vendors here that come highly recommended. It'll cost you $150 or so, but gains will be minimal on a stock car. The stock PCM program is pretty good.
If you get headers, or a cam, or something along those lines, a tune will help quite a bit.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
Slayer
Aug 17, 2015 03:55 PM
